10-16-2012 11:33 PM
Hi all....I try to plot date data (first column in array) to x axis in 3D bar graph follow by example in this link
http://forums.ni.com/t5/LabVIEW/3D-bar-graph-issues-using-2D-Y-Z-plane-and-timestamp/td-p/1923027
But I still do not succeed.
I'll be glad if you had any suggestions that could help.
Thank you
HiN
10-17-2012 01:03 AM
Hi Jubchay,
Here is an example of displaying the given timestamp. Only the 3D vision has the customized marker.
The 3D Bar is not suitable to display a lot of bars, which make the marker overlapped. So I only input the subset of 15.
10-17-2012 01:25 AM - edited 10-17-2012 01:25 AM
Thank you for this solution ![]()
If can't use 3D bar graph for display 2D bar graph
Can I use XY Graph to plot multi bar graph?
Do you have solution for XY graph?
Thank you very much ![]()
10-17-2012 02:08 AM
I don't have a solution at hand. But I know that you can use the legend to display the line graph as a bar graph.
10-17-2012 02:19 AM
Thank you but If i change line graph as a bar graph.
Single plot is OK but Multi plot is not OK because graph will be overlap
Thank you for answer if will try another way. 🙂
