3D graphics question
I have a 3D plot - rectangular solid and I can rotate it ok about x y and z. I only need z as the vertical axis so that Roll is around x, Pitch around y and yaw around z. The z axis must be vertical which sounds easy. What am I doing wrong?
(3,594 Views)
Accepted by tomnz
If i understand your Question Correctly, this is my suggestion (Axis value for Rotate Object are as follows(1,0,0)(0,1,0)(0,0,1)).
(3,557 Views)
Accepted by tomnz
If you want to have the Z-axis as the vertical axis, I think that you have 2 options:
Create a scene, rotate that scene, and then add your object to that scene (as shown below).
PC 3D Picture (mod)_BD.pngOr just rotate the camera view using the invoke node "Setup Camera" of the 3D Picture control.
Marc Dubois
(3,537 Views)
Thank you for that. I made the mistake of using the reference rather than the object when I was trying. Works well - here is the modified version.
(3,527 Views)
