3d printer simulation
I have some problems slicing a 3d .stl file because i should use arrays or such in order to use Z axis for layering.
The thing is I'm a rookie regarding Labview and my assignment was to simulate a 3d printer, including the control of all 3 axis..and temperature control of the extruder head.
I could really use some help, ideeas , everything will come in handy.
Thank you
Message 1 of 8
(6,037 Views)
First, do you have a document describing the stl file format?
Second, have you gone through the tutorials?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(5,999 Views)
Yes, i did go through various tutorials.Would you recommend something related to this?
I only have the .stl file..that i've already used it in Labview.
Message 3 of 8
(5,975 Views)
Can you already get the data from the file? I thought that was your problem.
Mike...
LabVIEW Champion
Message 4 of 8
(5,961 Views)
Accepted by 2dor4444
Have you tried to use the "Load STL Geometry.vi" function and the property node named "normal array"? That property node gives you X , Y , Z normal components of your stl file.
Message 5 of 8
(5,934 Views)
I did not know about that property..thank you very much ..that came in handy.But how can I use the values from the array indicator..any ideea of approach?
Message 6 of 8
(5,898 Views)
Yes, refer to the attached document. It is LabVIEW 2014
Good luck with your application
Regards.
Message 7 of 8
(5,878 Views)
How can i display this XYZ data in a table as numeric values?
Message 8 of 8
(5,543 Views)
