3d surface not plotting correctly
Just curious why this isn't making the "saddle" shape like it should. Just playing around and expanding my knowledge so this isn't exactly in need of a "high priority" response. I'm going for the equation y = x^4-z^4.
Also, while I'm at it, why does the Z array take 2-d data. It makes sense...but at the same time it doesn't make sense (at least in my head haha).
Message Edited by for(imstuck) on 06-08-2010 12:02 PM
Message 1 of 9
(5,320 Views)
Now that I look at it, I think part of my problem is that the equation is in the y= format rather than z=. Hence, I keep overwriting my arrays in the for loop. However, I will leave this posted and I'm sure someone will point me in the right direction.
Message 2 of 9
(5,315 Views)
Accepted by GregFreeman
You almost have it right.  In order to have the correct Z array, you need to change the data of x and y independently.  This snippet should give you the proper graph.
Applications Engineer
Message 3 of 9
(5,286 Views)
Could you explain in a little more detail why this is? For some reason I'm having trouble wrapping my head around it.
I think I am thinking too much "equation" and not enough "array's it's producing"
Message Edited by for(imstuck) on 06-09-2010 01:43 PM
Message 4 of 9
(5,277 Views)
Nevermind, I think I got it. You need to say ok, when y is -5 and x is -5,-4,-3... what is z for each of those values. Then store it in an array. Then when y is -4 and x is -5,-4,-3... what are the z values etc, etc
Anyways, thanks for the solution!
Message 5 of 9
(5,265 Views)
That's exactly correct.  If you want to think of it in equation format, this is actually z = x^4 - y^4.  The way you had it set up is more like a ramp function of z, but the points of y were in the function of x^4 - y^4 and the points of x where from -5 to 5.  There was no thrid dimension, as you mentioned earlier, because you were over writting the y component each time.  If you don't transpose the 2D array, you can see the two dimensional graph.
Message 6 of 9
(5,246 Views)
Let's keep with the theme of plotting 3D graphs incorrectly. Simple sphere using cartesian coordinates. Don't know what to do about the imaginary numbers. Apparently 2 years after getting a Purdue Engineering degree, I can't do Engineering anymore. Or my brain just is having trouble thinking this way. Or...I like to make excuses.
I found an example with active x plots, but I am trying to stick with this newer surface plot.
Feel free to use spherical coordinates if you want.
Message 7 of 9
(5,220 Views)
Ooops, attachment.
Message 8 of 9
(5,210 Views)
Hey!
I've been working on this on and off throughout the day and haven't quite figured it out but was able to figure a few things out.
To work with imaginary numbers LabVIEW has a complex data type. You can change all of your data types to be this by right clicking on your data and selecting Representation»Complex Double. This will allow you to make calculations using imaginary numbers.
As for plotting the sphere correctly, I haven't been able to completely figure it out but I did do the following and it got me a bit closer.
Instead of starting from -4 to create the axis range, I started from -5 and changed the number of iterations to 11. This gave me a choppy graph so I increase the number of iterations (101) and changed the axis step size from 1 to .1089. This gave me a sphere with a plane in the middle. I didn't quite figure out how to get rid of the plane, but thought I would share what I've done when troubleshooting this issue.
I'll try working on it again on Monday if I have time. I hope you enjoy your weekend!
Stephanie A.
Americas Marketing Manager
Message 9 of 9
(5,183 Views)
