4 channel oscilloscope
With this scheme a spawn error -200428 Value passed to the Task/Channels In control is invalid. The value must refer to a valid task. When i add block DaqmxBaseCreateTask.vi before DaqmxBaseCreateChannel.vi spawn new error -200220 Device identifier is invalid. In Measure&Automation Explorer my device is named NI PCI-6036E "Dev1". My system: WinXP, LabView 2013 with Runtime Engine and DAQmxBase and DAQmx 9.5.1 drivers.
Message 1 of 9
(3,753 Views)
Why are you using DAQmx Base functions? Try using the regular driver.
Message 2 of 9
(3,701 Views)
In menu Measurement I/O and DAQmxBase -> not all VI available.
Message 3 of 9
(3,695 Views)
Install a version of DAQmx that supports LabVIEW 2013 - 9.8 or later.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288377
Message 4 of 9
(3,676 Views)
On this page: http://www.ni.com/white-paper/6910/en/#eseries for WindowsXP and 6036E recommended driver is version 9.5.1mx.
Message 5 of 9
(3,669 Views)
But that version doesn't support LabVIEW 2013.  So if you want to use that card, you will need to go to an older version of LabVIEW.  Looks like LabVIEW 2011 is the latest version that DAQmx 9.5.1 will support.
Message 6 of 9
(3,660 Views)
Send me link to download on LabView 2011, i see this page and not found 2011 version: http://search.ni.com/nisearch/app/main/p/ap/tech/lang/ru/pg/1/sn/n8:28,ssnav:pdl/
Message 7 of 9
(3,626 Views)
Why? The daq device you have is supported in the latest version of DAQmx. Look at the readme.
Message 8 of 9
(3,610 Views)
Thanks, i install the DAQmx 9.9 driver and change VI in scheme from DAQmxBase to DAQmx and scheme is works. Now i need to upgrade scheme:
1. Scheme must save waveform oscilloscope data to any format.
2. Waveform must be scaled on Plot X or Plot X is must tune scaled.
3. Waveform must be stopped and fixed on Graph.
Message 9 of 9
(3,599 Views)
