4 wire RTD Agilent temperature measurement
the Problem is: I'm using LabVIEW 2019. can I read the VI from Keysight in LabVIEW?
Message 11 of 18
(932 Views)
The Drivers from Keysight are not related to a LV Version. I'm using them since LV 2010. It was former Agilent or HP.
If you have added them to the Instr.lib you'll find them  ath the Instr I/O tab.
Added the PT1000 Sub VI.
Message 12 of 18
(929 Views)
Thank you. unfortunatelly my programm doesn't work anymore on LV2019. It's working on LV2016.
I can't open the file. I should write it again.
Message 13 of 18
(921 Views)
You're welcome.
Please let me know if I can support you.
Here you'll find latest drivers:
https://www.keysight.com/main/software.jspx?ckey=1628832&id=1628832&nid=-11143.0.00&lc=ger&cc=DE
Just install/ expand to your instr.lib
Only need to change the Data Sub VI for RTD/FRTD by open it and change Meas? with Read?
Also attached my Sub Vi as LV2016 version
Message 14 of 18
(916 Views)
Thank you. I used this PT1000 SUB vi but it not working.
Message 15 of 18
(906 Views)
Could not work,
you are using 34970A, but me working with 34980A. Different Driver, and System.
Will check the old manual if I could find it anywhere.
Message 16 of 18
(895 Views)
So, what do you know about the SCPI language and the right commands for this unit?
First I saw, the configuration for the channel ( sensor) is just missing. Also, you are using as last command meas? instead of read?. This is just killing the complete configuration you made before and set it to a standard config.  Which is defined as 100Ohm.
Message 17 of 18
(874 Views)
I have to build a temperatur VI using meas command, ag34970A and I should give the Parameter for pt1000 measurment.
Message 18 of 18
(844 Views)
