64-bit Float to Hex
I am trying to convert a 64 bit number to hex, and the normal TypeCast does not seem to be working.
0.000063092
Using TypeCast to a hex U8 array or U64 , yields a hex value of 0x3F108A0840000000
Using multiple websites, if I convert the number to hex, I get 0x3F108A084E7A83CC
It appears that the top 4 bytes are not being converted in LabVIEW for some reason.
Kenny
(3,789 Views)
Accepted by Kenny_K
Your value is actually 0.0000630919967079535127
Once you show more digits on your input and enter the correct value, the results agree.
(Note that the closest you can enter is 0.0000630919999999999984).
That series of zeroes at your end tells me that your DBL was probably derived from a lower precision representation number. Where does it come from?
(3,779 Views)
Change the display format of your constant from 6 significant digits to something higher like 18 digits of precision.
You'll see your constant is actually something else and the rounding to 6 sig. figs. made it look like 0.000063092
(3,776 Views)
Yes, as I suspected, your number is actually derived from a SGL, and converting it to DBL does not really give you more significant bits. Here's the proof!
Your original incorrect result is at the bottom.
(3,758 Views)
Interesting.  I didnt realize that If I originally typed the value in a SGL, and then converted the numeric constant to a double, it would still retain the 0 afterwards.
I am trying to program the value 6.30920E-05 into a device.   To write the number to the device, it needs to be converted to HEX.
Got it now, after I deleted the NC and started with a double first, before I entered the value manually.
Kenny
(3,719 Views)
Usually the SGLs 7 digit precision is plenty (you only use 6 in your post), but when looking at bit level things like this appears. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,661 Views)
