7966R and 5781
ftp://ftp.ni.com/outgoing/
2012 - DDS.zip
I'm not sure the bitfile is going to work in 2012, so you may have to regenerate the DDS IP, then recompile to get this to work.
FlexRIO & R-Series Product Support Engineer
Message 11 of 16
(1,072 Views)
hi Dave.can u give me  an example vi which can clearly expalin
1.conversion of 16 bit data to 14 bit.&
2.14 bit conversion to 16 bit data
Message 12 of 16
(1,061 Views)
Message 13 of 16
(1,048 Views)
hello Dave. thanks for replying.How to configure DDS and what settings are to be done to make  DDS  generate variable frequency.
Message 14 of 16
(1,036 Views)
I want to generate a variable frequency from 1Hz to 40 MHz
Message 15 of 16
(1,021 Views)
You'll want to use the PINC input like the tutorial I linked did.  You'll want to be sure you manually set the FXP to 30,0 as show in this image.
Message 16 of 16
(1,011 Views)
