8 data bytes maximum for CAN messages received - why??
Can anyone answer this:
Why is there an 8 byte maximum on the number of data bytes in a CAN message that is received in LabVIEW?
Eimear
(3,403 Views)
If I read the CAN spec correctly, it says the number of data bytes is limited to 8 bytes.
(3,399 Views)
Hi Eimear,
smercurio is right. The CAN bus has only 8 data bytes per message.
Mike
Message Edited by MikeS81 on 04-18-2008 05:21 PM
(3,394 Views)
Thanks for the replies.  I read that in LabVIEW help, but was wondering if anyone knew why this was?
Eimear
(3,384 Views)
Because it's in the CAN spec, as has already been pointed out. Are you asking why the spec limits to 8 bytes? That question may be better directed at the writers of the spec. What difference does it make?
(3,381 Views)
It matters because one of CAN messages I can receive on Vector's CANalyzer has 14 bytes of information in the data field, and I want to receive this through NI USB-8473s in LabVIEW.  Does anyone know if this is a NI limitation in some way?
Eimear
(3,352 Views)
