Warren,
Good news on both accounts:
Warren Massey wrote:
> Recently I needed to build a VI (under Win98, LV 6.0.2) that was
> destined to be turned into an application with the App Builder. When I
> did so, I discovered one aspect of the application that did not behave
> the same as the VI, concerning the results that �Strip Path� returns.
> Since I wanted the VI and the application to both be functional I
> figured it would simple enough to put in a check to see if it was
> running as a VI or as an application and then handle the Strip Path
> results accordingly. I went looking for a VI property node item that
> would tell me whether the code was running as an application or VI and
> didn�t find one. I tried the NI web site but it was down. I called
> into NI and (after several annoying minutes on hold listening to a
> recording telling me how useful and available the NI web site was)
> asked about how to determine the running environment and was told
> there was no straight-forward way. I came up with a simple-enough
> workaround to my problem but there really should be a VI property node
> item to provide this information.
If you use an application property node, then under
Properties/Application, choose Kind. This will return an enumerated
with values of "Development System" or "Run Time System" depending on
whether or not you are running within LV or running a built app. (Too
bad NI tech support couldn't point you there!)
> A second wish-list item concerns �enum� constants. Basically I would
> like something akin to the ability available for controls and
> indicators to create a �strict type def� where you can make a change
> in one place and it will propagate to all places where the item is
> used. This strict type def�ing of enum constants would logically be
> coupled to associated enum controls and indicators so perhaps it could
> be an extension of the strict type def�ing that is already available
> for enum controls and indicators. [Why do I want this? State machines
> (case statements within while loops) built using enums are much easier
> to understand than those built with numbered states but are much more
> difficult to add or remove states because it is difficult to update
> all instances of the enums!]
You are right, this is very useful. It is also very possible. Just
create a typedef enumerated control with the values you want. Save it
to disk. Then, from the block diagram, use "Select a VI" at the bottom
of the pallette and go find the control in your file system. It will
appear as a constant on the block diagram, and will be connected to the
typedef. In this case, you don't even need a copy of the control itself
on your front panel. If you the same on the front panel, you will get a
copy of the control, which you can use to generate constants. One
caution - once you start using these typedef constants, be somewhat
careful about how you duplicate them. If you clone them (CTRL-drag),
the new copies will be linked to the type def. There used to be some
cases for which the copies would look the same, but not be connected to
the type defs. I can't duplicate this behaviour now, so maybe that was
fixed in LV6.
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
