ADCMT 6241 LabVIEW Example - Error When Running VI
Hello everyone,
I am trying to control an ADCMT 6241 precision source meter using LabVIEW, and I encountered an issue when running the example VI provided by ADCMT.
System Setup:
ADCMT 6241 connected via USB
LabVIEW (2017 32-bit)
ADCMT 6241 official LabVIEW driver and example VI
Problem:
When I run the example VI, I receive the following error:
(Poly VI 'Read.vi':SubVI is missing)
Has anyone encountered a similar issue with ADCMT 6241 and LabVIEW?
Any suggestions on debugging or modifying the VI to fix this error would be greatly appreciated!
Thanks in advance!
(601 Views)
Hi evan,
This error is not specific to your device driver, it's rather generic…
How did you install this device driver?
Did you even install it?
Did you place it in the expected folder location?
(587 Views)
Q: How did you install this device driver?
I installed the LabVIEW driver from this website:
https://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=4F36F5FEFF8F216EE04400144F1EF...
The version I installed is LabVIEW 2017.
Q: Did you even install it?
Yes, I am sure it is installed. The error message appears when running the example files that came with the downloaded driver.
Q: Did you place it in the expected folder location?
I’m not sure where exactly I should place it.
Is there a specific folder where it should be located?
Thanks for your response!
(557 Views)
