ADD hexa decimal Numbers
How to add hexa decimal numbers that are got in an array. An array size of 11. I need to add each element.
Message 1 of 12
(4,822 Views)
Accepted by rpr
Like this?
Message 2 of 12
(4,822 Views)
Or, more simply, by wiring the array into the Add Array Elements primitive from the Numeric palette.
___________________
Try to take over the world!
Message 3 of 12
(4,820 Views)
muks wrote:
Like this?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 4 of 12
(4,813 Views)
Coq Rouge,
I dont get it
Message 5 of 12
(4,810 Views)
I dont get it either
Message 6 of 12
(4,807 Views)
Oh sorry my posting only get half through. My network gave up for a moment
This much simpler. The other solution is just to muks work i think
Ps be aware of overflow then adding hex numbers
Message 7 of 12
(4,796 Views)
The output of the AAE primitive is the same type as the input, so you shouldn't have to worry about overflow.
Also, it should be noted that the solution posted by muks could be simplified by removing the Index Array primitive - you can just use the value from the indexing tunnel.
Message Edited by tst on 03.11.2009 11:32 AM
___________________
Message 8 of 12
(4,777 Views)
Yes :smileyhappy:
Message 9 of 12
(4,768 Views)
Then adding say several U16 numbers overflow may occur quicker than you expect. It was just an heads up.
Message 10 of 12
(4,765 Views)
