‎11-03-2009 02:15 AM
Solved! Go to Solution.
‎11-03-2009 02:17 AM
Like this?
‎11-03-2009 02:23 AM
‎11-03-2009 02:35 AM
muks wrote:Like this?
‎11-03-2009 02:37 AM
Coq Rouge,
I dont get it
‎11-03-2009 02:39 AM
‎11-03-2009 02:54 AM
Oh sorry my posting only get half through. My network gave up for a moment
This much simpler. The other solution is just to muks work i think
Ps be aware of overflow then adding hex numbers
‎11-03-2009 03:28 AM - edited ‎11-03-2009 03:32 AM
The output of the AAE primitive is the same type as the input, so you shouldn't have to worry about overflow.
Also, it should be noted that the solution posted by muks could be simplified by removing the Index Array primitive - you can just use the value from the indexing tunnel.
‎11-03-2009 03:46 AM
‎11-03-2009 03:48 AM
