API custom right-click menu in VIPM distribution
Hi all,
I am developing API, which is part of VIPM distribution. I would like for VIs of this API to have the same options as, for example, boolean palette - when you place a boolean function on block diagram, there are right click options "boolean palette" - which directly shows you that palette and also "replace - boolean palette" which allows you to replace given function with other boolean function without being forced to go through entire functions hierarchy. This is possible for many other functions, I also noticed that for example OpenG and MGI toolkits have this implemented. Can anybody advice me on how to add this functionality to my toolkit?
(3,290 Views)
Accepted by Rashek
This help documentation may help you: Add Palette to Library or Class
Unfortunately, the setting (in VI Package Builder) requires a Pro edition.
You can also do it by manipulating mnu files. This forum post describes a possible way to do this: Add Palette to Library or Class Bug
GCentral
(3,246 Views)
Thank you, I have pro version, just didn´t realize the options were right there.
(3,230 Views)
