ASAM-ODS Unit definition
I'm creating a file converter that should fit the ASAM-ODS standard.
I'm using the advanced "Storage/Data plugin" vis, From the File I/O palette. For now my test are based on creating an ATF file on my computer. Later on the Oracle Server with the asam-ods database.
The *.atf files I create can be read from "Diadem" and "AVL Concerto" too.
The problem i'm having is the association of a unit (rUnit) to my "MeasurementQuanties". I've understand that i have to pass a reference to the unit
INSTELEM MeasurementQuantity
  Id = 67;
  iName = "P_CV_CEE";
  rMeasurement = 3;
  rUnit = UNDEFINED;
  rQuantity = UNDEFINED;
  iDataType = "DT_FLOAT";
  iDescription = UNDEFINED;
  iSize = UNDEFINED;
  iSystemName = UNDEFINED;
  iChannelMode = UNDEFINED;
  iInterpolationMode = UNDEFINED;
  iDelayTime = UNDEFINED;
  iDeadband = UNDEFINED;
  iLocalName = UNDEFINED;
  LocalColumn = 67;
ENDINSTELEM;
INSTELEM Unit
Id = 45;
iName = "hhmmss";
rPhysicalDimension = 35;
iGain = 1.;
iOffset = 0.;
iSystemName = "hhmmss";
iUser = "AlmaAutomotive";
iProject = "Common";
iLastUpdate = "20100304183325000000000";
MeasurementQuantity = UNDEFINED;
quantities = UNDEFINED;
ENDINSTELEM;
I have to change the rUnit = UNDEFINED to something similar to rUnit = UnitID
Any help is appreciated! Smiley Wink
(5,494 Views)
are you using a specific example in Labview or your vi is similar to one of these? Can you tell me which one?
(5,451 Views)
Hello Tina,
thank you for your help.
I'm not an expert of asam-ods standard, so I read this and other articles to understand the standard.
At this link NI explain how to read/write this kind of files with some good example too.
There is no example on writing units to the measurement quantities (AoMeasurementquantity). I can write all others properties but the unit. I guess because it's a reference to a component of the BaseModel (AoUnit).
The vi I'm using is from the examples at the link above: it is "ASAM-ODS Example.llb\Write Measurement.vi
(5,437 Views)
Accepted by Davide_Galli
Hi Davide,
There are two cases to consider:
1) The unit you want to assign does not yet exist and has to be added to the unit catalog
2) The unit you want to assign already exists in the unit catalog
Here is some VBScript code that shows the main actions that need to happen.  In your case you already have the "Channel" references as your light green MeasurementQuantity reference array.
' determine subtypes of aounit and aophysicaldimension
dim unitEntity : set unitEntity = store.Model.Entities("aounit").SubTypes(1)
dim physdimEntity : set physdimEntity = store.Model.Entities("aophysicaldimension").SubTypes(1)
' I: unit does not exist and we have to create it in the unit catalog
dim channel : set channel = store.GetElementList("tdm_channel", "name=ch1", 1).Item(1)
dim mPhysDim : set mPhysDim = store.CreateElement(physdimEntity, "m")
mPhysDim.Properties("length_exp").Value = 1
mPhysDim.Properties("mass_exp").Value = 0
mPhysDim.Properties("time_exp").Value = 0
mPhysDim.Properties("current_exp").Value = 0
mPhysDim.Properties("temperature_exp").Value = 0
mPhysDim.Properties("molar_amount_exp").Value = 0
mPhysDim.Properties("luminous_intensity_exp").Value = 0
dim cmUnit : set cmUnit = store.CreateElement(unitEntity, "mm")
cmUnit.Properties("factor").Value = 0.001
cmUnit.Properties("offset").Value = 0
cmUnit.References("phys_dimension").Elements.AddReference(mPhysDim)
' now we have created the unit and can add it to the channel
channel.References("unit").Elements.AddReference(cmUnit)
store.Save
' II: Query the unit already added in case I
dim channel2 : set channel2 = store.GetElementList("tdm_channel", "name=ch2", 1).Item(1)
dim unitEntityName : unitEntityName = store.Model.Entities("aounit").SubTypes(1).Name
dim myUnit : set myUnit = store.GetElementList(unitEntityName, "name=mm",1).Item(1)
channel2.References("unit").Elements.AddReference(myUnit)
store.Save
Brad Turpin
(5,336 Views)
Thank you Brad.
I managed almost immediatly to write units in the correct way just following your tips.
Davide
(5,208 Views)
Ciao Davide,
I am trying to save data in atfx/atf file format (i have to save it in an ASAM ODS Database but i don't no anyting about asam ods standard.. so i think i have to save data as atfx file to save in asam ods database).
I have a problem, i don't find  "ASAM-ODS Example.llb\Write Measurement.vi"  used by you...where can i find it?
can you send me some vi as example?
(5,066 Views)
