08-14-2012 12:00 PM
I think this is a fairly simple question, but I just can't find the answer anywhere. Is there a way to access the project that was most recently deployed onto the cRIO-9024 and open that file into LabVIEW? The problem I am having is that the computer where all the code is developed and saved is not the one used during experiments in my lab where the software and hardware is actually needed, and I am hoping there is an easier way to get to the files than just having to copy them all over to the other computer every time I make changes. I'm guessing there is one really simple thing I need to do that I just don't know about, so any help would be appreciated.
Megan
08-15-2012 04:14 PM
Hi Megan,
If you are referring to a deployed executable, you cannot open that in LabVIEW. When the executable is built, the block diagram is stripped and turned into lower level code, so that is unfortunately no longer accessible.
