Accessing cluster in subvis
I am reading large data from a file and storing it in a cluster, I want to use this cluster in different sub vis to access and process the data. I am a beginner to labview programming and your help is appreciated.
Thanks !
(3,222 Views)
That's a pretty basic question. Before trying to do anything serious in LabVIEW take some time to go through the tutorials. Start here.
LabVIEW 2012
(3,205 Views)
hi
you can use, for instance, a notifier. See the master slave template.
N
(3,174 Views)
you can create SubVIs giving the cluster values inside it.
I made some screenshots to explain the steps:
1) Right-clicking on the VI-symbol on the FrontPanel and select show connector
2) Click the connector and then the FrontPanel object to make the connection
3) Repeat this for every value you want to give to the main-VI out of the subVI
4) Right-clicking on the connectors field and select show icon
5) save the subVI
The subVI can be included into the main-VI per drag an drop out of the windows explorer.
I hope this helps.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(3,146 Views)
rest of files...
(3,145 Views)
Accepted by rja2kor
Thank you very much for your detailed explanation. Since I was a basic user and took some time to go through many materials to understand the concept. Once again thank you for your support.
(3,044 Views)
