Active Silicon Phoenix Board
Hey everyone,
Would Labview be able to integrate frame garbber boards from Active Silicon?  I am trying to work with Active silicon phoenix D24CL but had no success so far.
Message 1 of 8
(4,705 Views)
Looks like just a COM Serial port from pg 15
you only need the command list and syntax from the manual.
Message 2 of 8
(4,699 Views)
Shouldn't the actual card itself show up as my devices under NiMax devices ?
Message 3 of 8
(4,695 Views)
Only devices from NI show up in MAX.
The datasheet mentions an SDK and a LabVIEW driver. Presuming that this is what you are using, you'll want to contact the vendor with any problems of their code.
Message 4 of 8
(4,668 Views)
of course it should not show up as a device it is a COM port!
Message 5 of 8
(4,663 Views)
True. How about the camera which is sitting on that COM port? Should it not show up?
Message 6 of 8
(4,649 Views)
No. It is not possible for the actual serial device to be detected.
Message 7 of 8
(4,642 Views)
p.s.
The camera is not connected to the serial port, is it? That does not make much sense to me. The com port on your frame grabber is what would be connected to the pc.
Message 8 of 8
(4,635 Views)
