Cannot Install NI-VISA Driver in Windows 7
When I install NI-VISA Driver in Windows 7,the computer show the error code 10. However it can run in Windows XP. How can I solve it?
Message 1 of 10
(4,894 Views)
It is a USB RAW device.
Message 2 of 10
(4,891 Views)
What version of the NI-VISA are you installing?
Do you have the right access rights in Windows 7?
Have you tried to disable your virus scan/firewall programs ?
Message 3 of 10
(4,889 Views)
The version of the NI-VISA is 14.0.1 Of cource, I have the right access rights in Windows 7. And I have tried to disable myvirus scan/firewall programs.
Message 4 of 10
(4,884 Views)
What does USB RAW have to do with installing NI-VISA?
Can you attach a screenshot of the error message?
Message 5 of 10
(4,869 Views)
The error messages are that the windows 7 cannot open the USB device, and error code is 10.
Message 6 of 10
(4,847 Views)
Again, what this to do with installation of NI-VISA ?
When does this error code appear?
Are you run some code in LabVIEW?
Are the device installed in Windows ?
The device still needs to be installed under Windows.
Message 7 of 10
(4,840 Views)
This is confusing. Your original post refers to an error when installing NI-VISA and now you say the error occurs with some device. Please explain with more than a handful of words what you are really doing. What sort of device? Where are the screenshots?
Message 8 of 10
(4,827 Views)
Sorry, I am late. Maybe I don't expain my question clearly.
 I want to let the PC communication with the MCU. So I follow the title "USB Instrument Control Tutorial" to get file of .inf.
However I cannot load the .int on Windows 7. Surprisingly, it can load on Windows XP.
My device is not a HID-class device.
Message 9 of 10
(4,799 Views)
Hi all,
I still be worried by the problem. I don't know how can I do? I have seen the following KnowledgeBase article.
http://forums.ni.com/t5/LabVIEW/Cannot-Install-NI-VISA-Driver-in-Windows-7/m-p/1166593/highlight/tru...
It can work on Windows XP.
Thanks.
Message 10 of 10
(4,787 Views)
