Active X for VLC player
Recently I want to get the Livestream from a camera. I have successfully got the the livestream with Python and VLC media player. I want to get the livestream in LabVIEW. So I think I can use the Active X for the VLC media player to get it.
But problem is that I have installed the VLC media player. But in the object list of the Active X, there is no correspondent object for the VLC media player. Does anyone know the reason?
Best regard
Message 1 of 11
(29,253 Views)
Message 2 of 11
(29,232 Views)
Hello TUDarmstadt LLX,
you have to install the corresponding plugin during the installation of the VLC Player:
Afterwards you can use the ActiveX Container or the ActiveX Automation Open to create a reference you can use:
ActiveX Container:
ActiveX Automation Open:
Since i recently created an example code snippet i have attached this too:
Cheers
Fabian Wehnekamp
Senior Technical Support Engineer
Message 3 of 11
(29,189 Views)
Hi Fabian,
I have done as what you write, but I still can not find the object for the VLC media player.
Best regard
Message 4 of 11
(29,182 Views)
Accepted by TUDarmstadtLLX
most likely you are using Lv 32 Bit and installed VLC 64bit, which in this case is not compatible.
Try to install the 32 bit version of vlc.
cheers
Fabian Wehnekamp
Message 5 of 11
(29,179 Views)
I have found the object for VLC media player, but for the invoke node, there is only one item with the name "getVersioninfo". There is no methed for add target and play item. Do you know why?
Best regard
Message 6 of 11
(29,168 Views)
Hey,
can you attach the vi which does not work?
cheers
Fabian Wehnekamp
Message 7 of 11
(29,166 Views)
hello,
Is it possible with LV2015 ?
Thank's
Message 8 of 11
(26,985 Views)
it's ok, I found the Active panel Smiley Happy
Message 9 of 11
(26,979 Views)
Hi Fwehne,
I duplicated the code you have shown to us. However, nothing happens. I wonder will you be able to tell the reason why?
I also tried with Windows Media Player, which works.
I have gone through some of the examples in this link:https://forums.ni.com/t5/Example-Program-Drafts/VLC-scripting-in-LabVIEW/ta-p/3515450?profile.langua...
I am not sure what they want to achieve, but the tool seems to be the dynamic link library rather than ActiveX.
I wonder if VLC ActiveX is functional or not in LabVIEW.
Kind regards,
Hao
Message 10 of 11
(23,070 Views)
