ActiveX container (MS spreadsheet 10.0) is empty on a computer without LabVIEW
Similar problem with this one:
http://forums.ni.com/ni/board/message?board.id=170&message.id=8717&requireLogin=False
sorry for asking the same quesio, but I still did not have it solved.   Smiley Sad
the executable file is working fine on the computers with LabVIEW installed, but the ActiveX container is empty on the ones without it.
registering the activeX control is the answer in the previous thread, but I was wondering which .ocx file needs to be registered on the computers to enable MS Excel with no LV & where the .ocx file can be find.  Is that everything I need to do to sort it out, or do I need to something else when building the executable file.
OS: win XP
LV version 7.1
Message Edited by fluencyu on 04-28-2010 09:44 AM
Message Edited by fluencyu on 04-28-2010 09:45 AM
Message 1 of 26
(4,271 Views)
What are you trying to do? Write data to spread sheet? You can use a "write to spreadsheet" vi for this. If you want to use a activex then choose a activex container and right click choose Excel._Application or Microsoft Excel Object Library which you will find in the drop down menu.
Message 2 of 26
(4,248 Views)
hi muks,
i've already insert Excel spreadsheet into LabVIEW using ActiveX container and the programme is woking well on the computers with LabVIEW installed.  however when I run the executable file which is built from the programme on a computer with no LabVIEW installed on it, the ActiveX container is still there but it is empty.  I found a post asking similar quesion, but I did not get it yet.  it says the ActiveX container needs to be registere, the *.ocx file,  but I do not know which file needs to be registered and where i can find it?
please see attached file which may explain the problem better  thanks
Message 4 of 26
(4,231 Views)
you can use regsvr32.exe for excel.exe located at  C:\Program Files\Microsoft Office\OfficeXX
Message 5 of 26
(4,223 Views)
hi,
 While buidling exe have you checked the option "enable activex server" ?.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 6 of 26
(4,214 Views)
hi  srikrishnaNF
yes I have ticked the ckeckbox of  'enable activex server' and there isa TLB file in the folder where the executable file is saved.
Message 7 of 26
(4,202 Views)
Did you try registering the ocx?
Message 8 of 26
(4,197 Views)
 Hi muks,
That is what I am asking Smiley Wink
I know I need to registering the ocx, but I do not know which *.ocx files I need to register onto the computers with no LabVIEW and where I can find these OCX files. New to ActiveX container.  sorry Smiley Sad
Message 9 of 26
(4,192 Views)
hi fluencyu,
  Which activex object you included into the container?Have you inserted this attached file or you imported any *.ocx file?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 10 of 26
(4,190 Views)
