ActiveX container (MS spreadsheet 10.0) is empty on a computer without LabVIEW
If you're running a LabVIEW program you'll need LabVIEW or LabVIEW Runtime Engine installed. Do the target computers without labview have the runtime?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 26
(1,722 Views)
the target computer has runtime installed but with no labview. and it is fine to run other exe files with no activex container.
I am using labview 7.1
thanks,
Fluencyu
Message 22 of 26
(1,719 Views)
hi ,
 Have you installed both owc10.exe and owc11.exe,just now i checked an exe.By installing both i could able to get that control,otherwise it is showing as "control cant be loaded"error.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 23 of 26
(1,708 Views)
Hi
I will try later today , as there is no target computer with no labview around me now
many thanks for your help
Fluencyu
Message 24 of 26
(1,705 Views)
Hi Fluencyu,
As a number of other forum users have pointed out, the most likely source of this problem is not LabVIEW but missing ActiveX controls. If you install the Microsoft Office web components onto the target machine, I think you should solve this issue. You may need to do a repair on the LabVIEW runtime engine so that it correctly finds the link but I suspect LabVIEW will find the dependancy.
Let us know how you get on.
Many thanks,
Andrew McLennan
Message 25 of 26
(1,637 Views)
Hi all,
I had a similar problem. I tried to load MS spreadsheet 11.0 control into acivex container ( LV10 and office 2003 ). LV just closed down. However the control would load into MS Word.
I downloaded and installed the web components ocw11.exe.  Succes...the control now loads into the container!. However, there are now 2 listings of the control when I do a right click on the container. One works the other doesn't.
cheers
Message 26 of 26
(1,486 Views)
