ActiveX container (MS spreadsheet 10.0) is empty on a computer without LabVIEW
HI srikrishnaNF
I am using MS spreadsheet 10.0 and I inserted it as a control rather than as a document.  Is it becasue of this?
I have not insert any other file, the excel in this programme is simiply as indicator with same function as table.  The reason I am using Excel in ActiveX container is becasue I have never used it before.  Smiley Surprised
Message Edited by fluencyu on 04-29-2010 06:09 AM
Message 11 of 26
(1,764 Views)
hi,
 The reason must be ,the system in you are trying to run the program may not have office xp installed..
Thanks and regards,
srikrishnaNF
Srikrishna
Message 12 of 26
(1,751 Views)
srikrishnaNF wrote:
hi,
Thanks and regards,
srikrishnaNF
You mean ms office? but then how did he get that ms spreadsheet 10?
Message Edited by muks on 04-29-2010 05:20 PM
Message 13 of 26
(1,747 Views)
hi fluencyu,
   If office xp is already installed ,then another option is you need to install the webcomponents of office...You can download and install from
   http://www.microsoft.com/downloads/details.aspx?FamilyID=982B0359-0A86-4FB2-A7EE-5F3A499515DD&displa...
   By installing this component only,you will get the activex object as microsoft office spreadsheet 10.0.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 14 of 26
(1,738 Views)
Hi all
many thanks for your help
I am working on this today and I will let you know whether it could be sorted
thanks,
F.
Message 15 of 26
(1,722 Views)
Hi
I have been working on this problem but still did not have it solved yet.
I built application with 'enable activex server' checked and installed office webcomponents.
I also tried to regsvr32.exe execel.exe, but it says it is not .dll or .ocx file and it can not be registered.
King Regards,
Yu
Message 16 of 26
(1,673 Views)
Hi ,
  Have you installed owc10.exe from the link i specified in the previous post.No use in using regsvr32 .
Thanks and regards,
srikrishnaNF
Srikrishna
Message 17 of 26
(1,660 Views)
Hi srikrishnaNF,
Yes I did.  But I still got nothing.  Smiley Sad
Fluencyu
Message 18 of 26
(1,647 Views)
hi ,
  which versions of msoffice are  there in your system and the target system where you are getting the error?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 19 of 26
(1,639 Views)
hi
I am usingoffice 2003 on the computers both for progamming and applying executable file
os for both computer are xp
I will upload an example (VI and executable file ) later
thanks,
Fluencyu
Message 20 of 26
(1,632 Views)
