Add Labels when creating a constant
I think the problem I am finding is that the control editor only allows you to see the front panel and not the block diagram. Yes, the lables are shown on the block diagram for the custom control (also, the same things happens wether is is a number or a string)
Message 11 of 16
(2,146 Views)
Accepted by topic author alecjcook
There is a setting that alows you to get labels of created constant by default (see Aristos first reply in this somewhat abandoned idea)
Tools >> Options >> Environment >> Tip Strips & Labeling >> Show Created Constant Labels
It is a bit dominant and I turned it off again after a while. As I said, in LabVIEW 2012 you can select all elements of the cluster (e.g. ctrl+click on each), the show all labels with a single right-click action.
Message 12 of 16
(2,132 Views)
Wilson54910 wrote:
I believe that the reason that the lables are not visible by default is because from looking at your previous post, you are using a cluster constant, containing numeric constants. Numeric constants do not have lables by default.
He says he is creating the constants by right-clicking (terminal or wire, I guess). The created cluster constant will inherit all labels of the original so they will most likely have labels.
Message 13 of 16
(2,129 Views)
   OK so Enviroment|Create Constant Lables Helped a little, but (see below) the left hand cluster is what im getting, and the right hand structure is what I want, any ideas?
Cheers, Alec
Message 14 of 16
(2,114 Views)
That is just a matter of label location.
I believe 2012 just got some new options for the default locations.
Question:
Have you concidered viewing your cluster constants as an icon and when you want to remind yourself what is in the cluster, ctrl-h (show help) switch to wire tool and flaot over the wire?
It will give you more info than just the labels and you will avoid the "explosion" that occurs when you add more elements to the type-def.
That is all I can offer at the moment.
Have fun!
Ben
Message 15 of 16
(2,108 Views)
I agree that labels in clusters are a bit of a mess. Here's a related idea you might like.
Message 16 of 16
(2,088 Views)
