Adding dc offset to analog signals
Hi everyone,
I am trying to generate a sine wave signal using myRIO 1900, and I have looked into the following post as a reference.
https://forums.ni.com/t5/Academic-Hardware-Products-ELVIS/frequency-matching-problem-with-myrio/td-p...
I am just wondering if I could modify the VI in order to add a DC offset to the sine signal.
Message 1 of 9
(7,208 Views)
Yes, just use the add function and add the offset before the output. Make sure that the final max amplitude does not exceed the output range.
Message 2 of 9
(7,177 Views)
Message 3 of 9
(7,118 Views)
Message 4 of 9
(7,106 Views)
 OA1,
can it output the generated signal through the A/O pin in the myRIO?
Re: Analog Output from Basic Function Generator.vi
Someone wrote "The Basic Function Generator.vi outputs a waveform/array while the AO Write One Update.vi reads a single value so its not the right AO vi to be used for signal generation." Is that true?
Message 5 of 9
(7,091 Views)
You can output a waveform if you program the FPGA to do so.  Use a DMA FIFO​ to pass the points from your RT code to the FPGA and have the FPGA read this FIFO and write each point to the analog output.
Message 6 of 9
(7,074 Views)
Hi crossrulz,
Do I have to change anything inside the time loop except replacing the "analog out"? because I don't have any experience using FPGA.
Message 7 of 9
(7,055 Views)
I am just wondering if we can add DC offset to the signals without using FPGA on myRIO.
Message 8 of 9
(7,005 Views)
You can always add an analog circuit to add a bias voltage ...
(BTW: If you check with a scope, did you used DC or AC input coupling?)
If signal plus bias is within the range of the anlog output a software solution is possible.
Greetings from Germany
Henrik
LV since v3.1
Message 9 of 9
(6,987 Views)
