Adding string to array
I am facing issue in write a string into array. I am reading a text file using Read from Text File.vi in a For loop and matching a string match pattern. VI which gives me desired string. Now the string which I have got at output, I am not able to put this string into array. I have tried doing the auto index function of for loop for creating the array. Please suggest a way to build the array.
Message 1 of 8
(3,203 Views)
Your task is really easy. Please post your code possibly in LabVIEW <= 2021 (maybe also a snippet or picture) to let us see where's the error.
Paolo
Message 2 of 8
(3,196 Views)
Hi Swami,
When you want to "build an array" you should consider using the BuildArray function!
Message 3 of 8
(3,191 Views)
 Please see the snippet for the code.
Thanks in advance.
Message 4 of 8
(3,170 Views)
Accepted by Rohan1612
When Match Pattern function fails to find a match, a -1 is issued in offset past match. Use this value to filter the output.
Unless your LabVIEW version is rather old, you may right click on the output tunnel making it conditional, then wire offset past match  >= 0 the conditional terminal:
Paolo
Message 5 of 8
(3,157 Views)
Hi Rohan,
This is not a snippet, it's just an image of your code. Snippets are special to LabVIEW: read the LabVIEW help to learn about them!
You already create an array of strings, so I don't know why you claim "you are not able to put the string into array"!?
Message 6 of 8
(3,145 Views)
Thanks for the solution. I could build an array.
Message 7 of 8
(3,115 Views)
Thanks GredW for the input on Snippets. I will surely look into it.
Message 8 of 8
(3,114 Views)
