Agilent E4440A display line and screen capture problem.
Have you tried the command page 78 of manual i linked you first ?
MODSAVT ? which saves a trace in module memory.
BR,
Vincent
Message 11 of 26
(2,304 Views)
You can try  the HCOPY command. The other possibility is to use the MMEM commands to save the screen capture locally, copy the file and delete the local copy after. See the attached command reference document.
Ben64
Message 12 of 26
(2,290 Views)
Hi friend r u back=. =
I got totally confused...
I am trying to du a HCOPY command anyway.
Message 13 of 26
(2,274 Views)
After placing a VISA read after VISA out, still got a timeout error..
Message 14 of 26
(2,263 Views)
I try to do a screen capture using intuilink, it gives me screenshots while the program isn't running, but fails to give me screenshots while the program is running, I think it is more or less like the labVIEW situation, the GPIB is giving out commands and meanwhile recieving data, is it this that causes the timeout error?
Message 15 of 26
(2,258 Views)
No, you can't really run two separate GPIB programs at the same time.
Since you have not provided the exact command you are sending or your code, it's impossible to say what is wrong with your code.
Message 16 of 26
(2,245 Views)
Hello Dennis,
The attached is my program, I am quite new to labview, my aim is to control the analyzer to measure amplitude at different frequencies and then save the screenshots on my pc.
Without the save screen part, which is a bit different from what I did yesterday, it is working alright.
But after adding the save screen command, it stops working.
+. + Knight please save me.
Message 17 of 26
(2,241 Views)
The error happens at the first VISA read, it gives a time-out error.
Message 18 of 26
(2,235 Views)
I'm posting by phone. Can you attach an image? No promises since I don't even have the manual for the instrument.
Message 19 of 26
(2,220 Views)
Thx again man, you can just help me check the structure. I am not quite familiar with the structure so it may cause error.1.png2.png3.png
Message 20 of 26
(2,214 Views)
