Align button where the 1st object is static and the 2nd or rest will align towards the static 1st object.
Hi there.
So basic questions:
How do I align a block, where the first one do not move and the 2nd one adjust to the 1st one?
E.g. below I would like my "Disconnect" button to be aligned with the "PLC IP address".
But when I go in and select them both, and selecting "Vertical alignment", I get this result:
What I would like is to have the "Disconnect" button static, so that the bottons do not move. I tried to "lock" them, but then I was not able to align the string "localhost" box to the botton.
(1,138 Views)
Hi Christian,
It is already aligned!
How do you want to align them?
Which alignment mode did you use? (top, middle, bottom?)
(1,106 Views)
@GerdW wrote:
Hi Christian,
Hi GerdW.
Well, I want them to be aligned vertical centered. Like below, which I did by manual moving it a bit down.
I used this function:
(1,102 Views)
Accepted by ChristianLiinHansen
Hi Christian,
  1. Hide the string control label
  2. Select both the button and the string, then align them at center.
  3. Move both (button+string) to the same frontpanel grid as your Connect button…
(When designing an UI I always align elements along the grid as much as possible!)
(1,097 Views)
Also be aware that when using front panel objects from the Silver category, there's some manual effort required if you want to get the alignment "pixel perfect". This is due to the fact that the bounding area of Silver objects is too big on the bottom and right, as you may have noticed.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(1,083 Views)
