Alignment of array of buttons with array of text on front panel
I can't gert these buttons to align with the textboxes. Should I use something else for the buttons array?
(4,046 Views)
Hi RHutchings,
why don't you set the buttons and "textboxes" aka strings to use the same height or width?
General advice: when you have a problem with a VI of yours you should attach that VI…
(4,042 Views)
(4,026 Views)
I set all the text and numerics to Tahoma 13. And the height of the buttons to 20.  I also hid the increment/decrement buttons on the numerics. They line up.
(4,019 Views)
It looks good but I really need the increment buttons on the # Bytes control.
(4,012 Views)
Accepted by RHutchings
OK.  Turn those back on.  Make the font Tahoma 14 on all the numerics and strings.  Set the button height to 21.
(4,006 Views)
