Alphabet_Order
Hi, I need some help! I'm trying to list/retain each letter in the alphabet in Column 0 of the appended array shown. Each time I press the Key-In "OK" Button a letter of the alphabet should appear - and does, but I need another shift register or sequence structure to retain each letter as:
a = 1
b = 2
c = 3
I don't want to make this over complicated - but it might be too late...lol.
Message 1 of 10
(1,669 Views)
Not sure what are you trying to achieve. You can convert number to ascii character.
https://tmesystems.net/
Message 2 of 10
(1,620 Views)
Accepted by _Phobos
Maybe something like this?
Message 3 of 10
(1,609 Views)
This appears to be a "homework" problem, which you have restated in such a way that it is unclear what you are supposed to be doing (and thus difficult to help you understand how to approach this problem).
Why don't you post the assignment itself?  Is there a "timing" requirement?  What is "Key In" supposed to do?  Are you supposed to create a 1D Array of Strings that start with "a = 1" and end with "z = 26"?  Are you supposed to create a 2D Array of Strings, the first column of which contains "a" to "z" and the second column contains "1" to "26"?  Why are there timers in your code?
Have you discussed this with your Professor?  with your Classmates?
Message 4 of 10
(1,570 Views)
Thank you! Just out of curiosity, how did you think - to take this approach? And I see that you're using a "96" unsigned byte constant. What does that accomplish?
Message 5 of 10
(1,554 Views)
Thank you for your response and showing clarification 97 is asci "a"! Much appreciated!
Message 6 of 10
(1,549 Views)
btw. ZhiYang-Ong answered my question about the 96 unsigned byte constant - fyi.
Message 7 of 10
(1,548 Views)
I have over 50 years programming experience and seen it all, so this took literally seconds for me. There are thousands of equally valid possible approaches. Now you got a starting point, so try to come up with five more solutions as an exercise! Try it and make sure it works.
Study every detail of the solution. Why do we convert to U8? What does typecast do, exactly? Why is N=26? Why is there a wait because it "seems" to work equally well without it? etc.
Now rewrite it (1) using an event structure, (2) using a singe loop, (3) so it goes back to step one after all characters are shown, (4) modify it so it produces uppercase letters, (5) modify it so the output is a single string adding a line with each step. (6), modify it so it stops automatically after all lines are displayed, (7)... etc.
If this is homework, be aware that your teacher reads this forum so make sure to do some creative changes and be prepared to answer any questions about any part of the code.
Study this, maybe you see a pattern. 😄
Message 8 of 10
(1,539 Views)
On a somewhat unrelated note, can you explain to me how the solution to this problem works?
Solved: Sort Array - NI Community
Message 9 of 10
(1,273 Views)
It is a solution to a different, somewhat obscure problem and seems quite useless for typical scenarios. What part don't you understand?
Message 10 of 10
(1,226 Views)
