Analong Output defaults to 1V
I have a NI-9264 Analog Output module that I'm using to set a proportional valve. I'm having an issue where every now and then the module will output 1V regardless of command or restarting LabVIEW. The only way that seems to kick out of it is opening up MAX and setting the output to zero, when I open max to set the output the default value is 1V, is there a way to change this to 0?
In my code I'm just running a simple write command that works fine, like I said this issue just happens periodically and I can't seem to kick out it through LabVIEW.
(2,561 Views)
Can you publish your code?
It will be important to see how is configure the DAQmx task
(2,513 Views)
Here is how I configure my tasks, I'm creating 6 and scale my analog modules using a custom vi I've attached.
(2,497 Views)
