ImageJ implementation or equivalent in Labview
I am doing particle counting and analysis from micrographs using the ImageJ software. I was wondering if there was any way to implement this into labview or software for labview that does the same things as ImageJ. I know of OpenG but I am looking for something a little more complete. Thanks
-Ryan
Message 1 of 19
(11,221 Views)
LabVIEW has some image analysis modules. Try clicking the Products link at the top of the page and look for the LabVIEW toolkits.
___________________
Try to take over the world!
Message 2 of 19
(11,219 Views)
I saw something in the IMAQ toolkit. Also cell counting, etc...
Dai
LV 7.1 - WIN XP - RT - FP
Message 3 of 19
(11,215 Views)
Dear Ryan,
I would be very interested in a solution for integrating ImageJ in Labview. Have you been able to do this, or have you switched to IMAQ or Vision VI's?
Kindly regards,
Christian Breukers
Message 4 of 19
(11,178 Views)
Hey everyone,
I am planning on doing the same thing..i.e integrating ImageJ with Labview. I am actually developing a Labview interface for our multiphoton laser microscope and wanted to do Z-Stacking with ImageJ, the only problem is that i havent had any luck integrating it with labview,
Anyone has done it yet or know whats possible?
Muttee
Message 5 of 19
(10,977 Views)
Hi Ryan,
If you have a macro that runs your particle algorithm it is fairly simple.
Attached a small VI which we used and developed at the University of Twente (BioPhysical Engineering).
Make sure your ImageJ macro is in the C:\Program Files\ImageJ directory.
Kind regards,
Christian Breukers
Message 6 of 19
(10,952 Views)
I tried to use the RunImageJ.vi with a simple imageJ macro but the .vi returns an error
"Error 2 occurred at System Exec.vi. Command was "java -cp ij.jar;. RunMacro FFTthenLinePlotIJMacro.txt  "
Possible reason(s):
LabVIEW:  Memory is full."
Can anyone tell me what I am doing wrong?
Dewey
Message 7 of 19
(10,853 Views)
This is an old post, but for anyone interested in a solution, I've created a plug-in for ImageJ that opens LabVIEW VIs. VIs opened in this way can easily pass images and other info to ImageJ, and vice versa.
http://www.imagejvi.org/
Matt Kirk
Inventor of ImageJVI
Message 8 of 19
(8,971 Views)
how can I connect imagej with labview 2013 (64-bit)
Message 9 of 19
(8,514 Views)
Before run ImageJ on LabVIEW, I recommend you to try command-line to see the macro works or not.
>java -jar ij.jar -batch your_own_macro.ijm
To type above command, if your platform is Windows, Start bottun -> accessary -> command prompt
See the following URL for Running ImageJ from the Command Line,
http://rsbweb.nih.gov/ij/docs/guide/146-18.html
Message 10 of 19
(8,202 Views)
