ImageJ implementation or equivalent in Labview
Hi Kirk,
any chances to re-upload the http://www.imagejvi.org/ as the link is dead I think.
seems all the link related to imagejVI is dead. http://www.imagejvi.org/index.php/installation.html
thank you in advance.
Message 11 of 19
(2,868 Views)
racd ha scritto:
Hi Kirk,
My Symantec antivirus blocked an attempt to access that site because "it's a known dangerous site".
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 12 of 19
(2,854 Views)
weird, I don't have any restriction to access it.
maybe you can go through here
https://imagej.nih.gov/ij/plugins/index.html
and look for the :
ImageJVI: Plugin that opens and controls LabVIEW Virtual Instruments
Message 13 of 19
(2,848 Views)
Did you get how to integrate ImageJ to Labview? Run imagej(fiji) macro program in labview
Message 14 of 19
(2,531 Views)
I made an example vi for running ImageJ's macro on LabVIEW by using System Exec VI.
See attached files.
Copy the macro (LabVIEW.ijm) to C:\Program Files\ImageJ\macros, and Run the attached VI.
See the following message I posted four years ago. Move to C:\Program Files\ImageJ before run "java -jar ij.jar ..."
Before run ImageJ on LabVIEW, I recommend you to try command-line to see the macro works or not.
>java -jar ij.jar -batch your_own_macro.ijm
To type above command, if your platform is Windows, Start bottun -> accessary -> command prompt
See the following URL for Running ImageJ from the Command Line,
http://rsbweb.nih.gov/ij/docs/guide/146-18.html
Message 15 of 19
(2,513 Views)
When I typed on command-line to see the macro works or not , >java -jar ij.jar -batch your_own_macro.ijm , its showing unable to access jar file.
But when I tried labview program , its showing sucess.
Message 16 of 19
(2,506 Views)
I got a program for calling Fiji(ImageJ) through LabVIEW.
I have attached VI. If possible please install Fiji(ImageJ) software.
I have developed a macro program with extension .ijm in Fiji . In that macro program, I have written macro program in which user provides number of rows , columns, type and order of stitching, amount of overlap, etc
based on grid/collection stitching in Fiji . I want my LabVIEW program as which user provides number of rows , columns, type and order of stitching, amount of overlap, etc and Fiji runs and provide output. I want LabVIEW as front end and Fiji (ImageJ ) as backend. Can you give  idea on how we can run ijm macro?
Message 17 of 19
(2,498 Views)
I think following URLs are useful for you. Also I attached sample VI and macro.
https://imagej.nih.gov/ij/docs/guide/146-18.html
-macro analyze.ijm
-macro analyze /Users/wayne/images/stack1
https://imagej.nih.gov/ij/developer/macro/macros.html#cli
name = getArgument;
if (name=="") exit ("No argument!");  path = getDirectory("home")+"images"+File.separator+name;
setBatchMode(true);
open(path);
print(getTitle+": "+getWidth+"x"+getHeight);
Message 18 of 19
(2,478 Views)
In my case I am using a plugin called 'grid/collection stitching'. Not like passing arguements
Message 19 of 19
(2,459 Views)
