Another LabVIEW Crash
Hello everyone,
It looks like this is something that I may need to bring to R&D's attention.  Can any of you provide a step-by-step procedure and small piece of code that will reproduce this error log file?
Janell Rodriguez | Applications Engineer | National Instruments
Message 11 of 25
(3,491 Views)
Hi, As I mentioned these crashes are random and not repeatable. I have seen crashes with very simple code where there is no code on blcok diagram and just playing with front panels.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
Message 12 of 25
(3,478 Views)
Sige, Ron Brown,
Have either of you been able to reproduce this crash?  If so, please let me know.
Sincerely,
Message 13 of 25
(3,460 Views)
Hello Sheetal,
Were you using the LabVIEW Real-time Module?
Message 14 of 25
(3,455 Views)
Hallo All,
I am also using 8.2 and I am also having same problem. Let me know if somebody find any solution for that. So I kindly request if some body has any solution then please let me know as soon as possible.
Thanks.
Message 15 of 25
(3,420 Views)
Hi Janell ,
No, I do not use labview realtime.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 16 of 25
(3,408 Views)
This was reported to R&D (#42IC6IK8) for further investigation. If any of you have more information about crashes occurring at ThEvent.cpp(152), please let us know.  Thanks for the feedback!
Thanks!
Janell R. | Applications Engineer
Message 17 of 25
(3,392 Views)
Ok. I have a new problem  now!
I have a VI with 3 charts and few other controls. All controls and Charts update fine for few minutes and then they stop updating. Charts don't scroll. My VI is still running. If I put in highlight mode I can see its moving from one control to another but controls do not update.
All I am doing is reading microphone input and displaying on chart. One chart shows peak and other chart shows FFT.
Any idea?
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 18 of 25
(3,370 Views)
I think my problem has something to do with sound input configure vi. what should be these values for normal sound card input measurement. (Sound format and #of samples/sec) I am capturing input through sound card and detecting noise.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 19 of 25
(3,364 Views)
We have the same Error in a huge application. The development of this Application startet with LV 8.0 where everything is OK. If we use LV 8.20 or 8.21, every time after finishing the Application the error occurs during closing the LV start window.
We have the same behavior if we run it as EXE or inside LV.
This error forces us to stay at LV 8.0 which has some other disadvantages against 8.2 or 8.21.
Is there at least any way to prevent LV from showing fatal error messages? Of course we could use Microsoft Taskkill for closing LV but there should be better solutions...
Thanks!
Message 20 of 25
(3,122 Views)
