Anybody has a LabVIEW 6 driver for Agilent 8510C?
Hello. I have LabVIEW version 6 and I am trying to talk to an Agilent 8510C network analyser. I seem to be able to communicate with the instrument only for sweep, number of points, etc, but I cannot transfer any data from the 8510 to the PC (to export data to Excel). I tried saving data to memory, and using the "outpdata, outpfrmt, outpraw" commands to transfer numbers to PC with no luck.
The NI site has only labVIEW 7 and 8 driver versions, so I am stuck. Has anybody developed anything for L.6? Any help much appreciated
(2,832 Views)
Give this a try. In the future, if you need other drivers, it would help if you would attach the driver from NI's site. It's pretty simple to do a save for previous version assuming someone still has older versions of LabVIEW still installed. A lot of us do so it just makes it easier to do the down conversion if you attach the file you need converted.
(2,823 Views)
thank u!
I will try it and see if I can save any data to the PC..which seems to be the problem. Thanks
(2,818 Views)
