Anyone please help,
Anyone please help, how can i display a random display of string in a tab then if i click on a next button, the program shall replace the previously displayed string by another random string on the same tab? is this possible? what should i use to do this?
(2,933 Views)
Accepted by ronronturon
rndom.JPGNeeds polish but you get the idea.
(2,914 Views)
I'm not very sure what exactly you are trying to do but i think you can refer the attached vi, you'll get some help from where you'll be able to go ahead on your own..
regards,
Nitz
(Give Kudos to good Answers, Mark it as a Solution if your problem is Solved;))
(2,911 Views)
What you have uploaded, Write what you want and what is expected.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,908 Views)
