Append 1D Array of strings to spreadsheet
This is killing me!
I have an existing .csv file with header.
I want to add a row of text data(append) and repeat onto the next row when needed.
Seems to me I used to just wire my 1D array of strings to the 1D input of the Write to Spreadsheet.vi but that functions seems to have disappeared
Message 1 of 11
(4,596 Views)
Write delimited spreadsheet gives you all the functionality you need.
Message 2 of 11
(4,586 Views)
I thought so too but for some reason my write to spreadsheet does not allow 1D input
Message 3 of 11
(4,575 Views)
There is a 1D Data input to the Write Delimited Spreadsheet VI.
Message 4 of 11
(4,566 Views)
Not on mine!
This is what is driving me nuts. I've used that function numerous times but at the moment the is ONLY a 2D option.
If I right click the icon and select Automatic input it still rejects my 1D input.
Message 5 of 11
(4,557 Views)
I just tried it in LV2016 and it works as it is suppose to.
I think the problem is with LV2019
Message 6 of 11
(4,547 Views)
There should be two inputs, one for 2D and one for 1D right below it.
If you don't see that, double-click the function (it's just a plain VI under the hood!) and see if somebody modified it. In that case, you might have to reinstall LabVIEW.
Message 7 of 11
(4,545 Views)
Hi Murph,
attach your version of WriteDelimitedFile.
What is the path to that function? Did you accidently change/overwrite that function despite it is in the VI.lib?
Message 8 of 11
(4,543 Views)
Accepted by Murph
Mine works fine in LabVIEW 2019, so check my message above (here's the picture from the 2019 context help)
Message 9 of 11
(4,539 Views)
I went in to look at it and YES, it had been modified.
Looks like I was able to add it back and it appears to be working.
THANKS
Message 10 of 11
(4,534 Views)
