Append Waveform, keep time stamp
I am reading from a USB module with data acquisition at 500 Hz. In order to achieve this within the loop time, I need to acquire multiple samples per loop. Once I have those samples (output in waveform), is there a way to append the waveform that maintains the time stamps?
I am currently using the "get time array", then inserting that data into a shift register of the same. I'd like to re-insert that data into the rest of the appended waveform to make writing the information that much easier. If that doesn't work, I'll probably just stick to making a 2D string array to write the data.
Thank you!
Message 1 of 28
(8,022 Views)
Look for the Append Waveforms VI.  It is in the Waveform->Analog Waveform palette.  I think that does what you are looking for.
Message 2 of 28
(8,011 Views)
I tried the append waveform, but when I do that all dt and timestamp data appears to be removed (dt goes from .002 to 1)
Message 3 of 28
(7,998 Views)
Please show your code. You are doing something wrong.
Message 4 of 28
(7,987 Views)
I am using Labview 2014, and have included the .vi and picture.
Message 5 of 28
(7,949 Views)
Here is the picture with timing visible.
Append Waveform
Message 6 of 28
(7,945 Views)
You have an unitialized shift register. That is why you have the default dt of 1.
Message 7 of 28
(7,938 Views)
Do I need a seed value for the initialization? A constant doesn't appear to solve the problem. Thank you for your help on this.
Message 8 of 28
(7,931 Views)
I'm hoping to be able to be able to keep the t0 data from the first measurement.
Message 9 of 28
(7,930 Views)
You need the correct dt and t0 in the initalizing constant Leave Y and Attributes empty.  dt and t0 of waveform B are ignored by append waveform and the dt and t0 on the SR will be preserved and propigated through the loop.
Message 10 of 28
(7,915 Views)
