Application EXE from vi error win32
i make my vi file, and build an I create an executable ( build it on win 7 . 64 bits) ( on my cumputer it work fine)
i put the three files on another computer ( win xp )
Application.aliases
Application.exe
Application.ini
but i get the error( not valid win32 application error ) message when execute exe file
Help me Please,
Thank you in advance.
Message 1 of 13
(5,374 Views)
Hey khga123,
is the correct runtime engine installed on the xp machine?
CMW..
Message 2 of 13
(5,359 Views)
no, What is Runtime engine ?
Thank you for respond!
Message 3 of 13
(5,345 Views)
The Run-Time Engine is a program that must be installed on any machines you wish to run the executable on.  You can either bundle it in when you build an installer (instead of a standalone exe).  Or just download the appropriate version from National Instruments and install it on your Windows XP machine.  What version of LabVIEW do you have?
Here are a few of the more common versions:
LabVIEW 2013 (32 bit) - https://www.ni.com/en/support/downloads/software-products/download.labview.html#359472
LabVIEW 2013 (64 bit) - https://www.ni.com/en/support/downloads/software-products/download.labview.html#359473
LabVIEW 2012 (32 bit) - https://www.ni.com/en/support/downloads/software-products/download.labview.html#359462
LabVIEW 2012 (64 bit) - https://www.ni.com/en/support/downloads/software-products/download.labview.html#359463
LabVIEW 2011 (32 bit) - https://www.ni.com/en/support/downloads/software-products/download.labview.html#359453
LabVIEW 2011 (64 bit) - https://www.ni.com/en/support/downloads/software-products/download.labview.html#359454
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 4 of 13
(5,340 Views)
Hey,
for information about the runtime engine, check out this link,
https://www.ni.com/docs/en-US/bundle/labview/page/using-the-labview-run-time-engine.html
In your case I would recommend to create an installer.
Mark the "Automatically select recommended installers" in the Additional Installer palette. Then install your application on the second machine.
CMW
Message 5 of 13
(5,337 Views)
Thank you,
i will see if it works 🙂
Message 6 of 13
(5,329 Views)
1) Make sure you have the right RunTime Engine installed on the second computer
2) Make sure you didn't build your EXE with a setting that you need at least Windows 7 to run it.
GCentral
Message 7 of 13
(5,317 Views)
Thank you all for your respond,
now another problem come, when i do all what you said.
on win xp installer said error message that it only work on 64 bits windows!!
how i can make it work on 32 and 64 bits windows,,??
Message 8 of 13
(5,288 Views)
Build it as a 32 bit exe using a32bit LabVIEW IDE.  Yes you can have LabVIEW x32 and LabVIEW x64 on the same machine using the same license key.
Message 9 of 13
(5,278 Views)
ok Thank you 🙂 Smiley Happy
Message 10 of 13
(5,268 Views)
