Arbitrary waveform and Append waveform
Hello everyone!
I Intend to create an arbitrary waveform and append it with a classical one (sine wave), the working frequency of appended waveform I want to be in the range of 5k-200k Hz.
In Append waveform DBL, which channel is the dominant frequency?
In Arbitrary waveform VI, how to adjust the frequency and samples to achieve a range of 5k-200k Hz?
I try to increase the frequency of this appended waveform to 5k-200k Hz .......
(2,376 Views)
Hi Vlad,
 Did you notice that coercion dat at AppendWaveforms function? Do you know its meaning?
  • You create an array of samples using one function and a waveform using a different function: when you want to define waveforms you should create waveforms in all your code!
  • You can convert an array of samples into a waveform using the BuildWaveform function…
  • You could look inside the AppendWaveform function to learn how the waveforms are appended. Usually the first/upper waveform defines t0/dt… (After looking into that function it checks the dt value of both waveforms.)
  • When you want to change the frequency of a waveform you just need to manipulate the dt item of that waveform!
(2,368 Views)
I want to create a custom control signal to operate a power MOSFET transistor to generate a variable electromagnetic field through an antenna.
I have attached an image with an example of a command signal that I would like to generate (a combination of arbitrary amplitudes and classical waveforms).
What would be the best way (functions, blocks....) to make the signal through Labview? ....as hardware I use USB NI 6341.
(2,306 Views)
Hi Vlad,
I see some ramps and sine signals in your example image…
Use any of those SignalGeneration functions to build your waveform!
(2,303 Views)
