‎07-20-2021 04:35 AM
‎07-20-2021 04:42 AM - edited ‎07-20-2021 04:45 AM
Hi Vlad,
@VladTepesRo wrote:
In Append waveform DBL, which channel is the dominant frequency?In Arbitrary waveform VI, how to adjust the frequency and samples to achieve a range of 5k-200k Hz?
Did you notice that coercion dat at AppendWaveforms function? Do you know its meaning?
‎07-21-2021 02:43 AM
I want to create a custom control signal to operate a power MOSFET transistor to generate a variable electromagnetic field through an antenna.
I have attached an image with an example of a command signal that I would like to generate (a combination of arbitrary amplitudes and classical waveforms).
What would be the best way (functions, blocks....) to make the signal through Labview? ....as hardware I use USB NI 6341.
Thank you very much!
‎07-21-2021 02:52 AM
