Averaging of each element of array
@altenbach wrote:
Note that this is very efficient because it just maintains the sum and adds the new values while subtracting the oldest.
However, the sum can get corrupted, not just by NaN, Inf and -Inf, but also by (relative) large (positive or negative) numbers:
10E23 + 1.0 + -10E23 != 1.0
I've found where I needed moving averaging, guarding for NaN, Inf and -Inf made things slower than simply keeping a history and averring it. And that also solves the range problem.
There will be a break even point, but for averages of up to a few k samples, the naïve method isn't worse than a sophisticated method with protection against NaN, Inf and -Inf.
Of course, if the signal doesn't get NaN, Inf, Inf or has a large range of values, keeping the sum is more efficient.
Message 21 of 33
(1,340 Views)
@altenbach wrote:
@msabah38 wrote:
I used the vi Means_PtbyPt.vi ‏27 KB in my program, but the results are not getting updated. I have attached my VI. Can you please tell where I am going wrong.
(I am not going to troubleshoot an unknown, untested subVI, but maybe it is buggy.)
From anyone else I'd take offense 😄 Luckilly I documented the code to the point where it could be maintained by someone other than the original author. (unlike some posters I could name)
Give me a moment to boot the laptop.  Most likely the input array is size 0 yielding a zero iteration for loop and the output SR cannot update.
Message 22 of 33
(1,329 Views)
Accepted by msabah38
Race Condition
Followed by the wrong (bugged) version of Means PtbtPt.vi
Delete the previous Means PtbyPt.vi which autoindexed the uninitialized Feedback loop.  Use the attached vis backsaved to 2015
Message 23 of 33
(1,320 Views)
Not sure why you wouldn't use a circular buffer with a pointer (as suggested in the 3rd reply).
A rotate and replace is going to be slower than it needs to be.
Message 24 of 33
(1,278 Views)
Yes, of course. Good point. It would be trivial to eliminate the running sum and do the averaging with each iteration. Both versions are described in my talk, of course.
Typically, data from an instruments will be well quantized and based on  FXP (12 bits .. 16bits?) and thus will fit  into a DBL with bits to spare. Of course if this runs for years at GHz, truncation errors will eventually start to accumulate. 😄
Message 25 of 33
(1,270 Views)
It was more of a time issue. I just looked at the picture and thought it was loosely based on the stock scalar ptbypt mean, but I did not inspect it in detail because I already had code that basically does the same with less and more "in-place" (sure hate those "insert into array thingies" I saw 😄 ). All I know was that it did not work so I though the original author would be better suited to look into it.
Message 26 of 33
(1,267 Views)
Absolutely and totally adapted from the original PtbyPt vi.  I would have used a circular buffer myself and prepended the build Array.   Some of the cases are not worthy of mention EXCEPT on the Rube-Goldburg thread! but it does protect against inf and nan.  I never looked at the sub vi in the original.  I bet it would cause migraines.   (I'll leave that speculation to a research opthomologist)
Message 27 of 33
(1,258 Views)
Prepending is also slow. If you want some speed, the buffer needs to be circular, and the data shouldn't be moved..
Alternatively, you can double the buffer in size, and replace new samples in two locations (index and index + size). Now you can always get all ordered samples fast. At the expense of slower writes and more memory.
Don't forget about the big vs small numbers! They are just as bad as NaN and (-)Inf, only even more overlooked.
Message 28 of 33
(1,246 Views)
As I said, this is probably not an issue with measurement data where even a 24 bit analog input has manageable range between smallest and largest. Personally, I still like the exponential filter alternative where really old data simply disappears below epsilon anyway. (Still needs to be protected from NaN and Infs, not shown in my code)
Message 29 of 33
(1,237 Views)
My take is "Mean means Mean."  There is nothing to stop you from using a PtbyPt filter if a filter is needed other than the filter vi would also need to be revised to handle an array input as well.
Message 30 of 33
(1,230 Views)
