BNC 2090 single ended mode errors
I have a BNC 2090 for acquiring 12 channels signals using the DAQ 6052E CArd, connected via SCXI 1180. I have configured the Channels in hardware and software as single ended NRSE since I have 12 signal that need to be measured and the 6052E has 15 channels in SE mode ( ch0 is for the SCXI CHASSIS).
On the BNC 2090, the configuration of the channels is
0 1 2 3 4 5 6 7 (UPPPER CHANNELS)
8 9 10 11 12 13 14 15 (LOWER CHANNELS)
When I connect the 7 of the 12 signals ( from Channel 1 – 7) , I can see signals perfectly.
However when I connect the remaining 5 (channels 8 -12), that seems to ‘greatly attenuate’ and DISTORT the signals on the ‘UPPER” channels. If I disconnect the lower 5 channels then the upper channels read correctly.
I have attached some snapshots of the graphs (NON FILTERED). They are self exaplatory.
Am I creating some ground loops?. If yes, then how can I remove them ?.
(2,699 Views)
Hello Aspired,
What type of signal are you measuring (Is the signal source grounded or not)?
If you suspect having ground loops, the manual for BNC-2090 located at http://www.ni.com/pdf/manuals/321183a.pdf show how to reduce the effect of ground loops on page 14. The manual also has very good information about setup and configurations.
Hope it helps...
Serges L.
(2,684 Views)
