BNC-2090
Is the BNC-2090 rack-mountable connector block compatible with USB 6281 NI ?
Thanks.
(3,958 Views)
Hi clourenco,
the BNC-2090 is just a connector block. As long as you can find a suitable connector cable it should be compatible to your USB6281…
- Did you ask the NI support? What did they answer?
- You should exactly name the hardware you use. There are several versions of both devices, like BNC-2090 or BNC-2090A. - Which connector does your USB6281 provide? Screw or mass terminal?
(3,920 Views)
Accepted by clourenco
All sorted out now. Thanks!
(3,897 Views)
