[BUG] LabVIEW crashes when replacing a Waveform control with a numeric array
 Steps to reproduce:
  1. Start LabVIEW
  2. Create a new VI
  3. Please a Waveform control on the front panel
  4. Right click the Waveform control and select Replace -> Silver -> Array, Matrix & Cluster -> Array - Numeric (Silver)
  5. Watch LabVIEW crash with internal error 0xC9381CDA in datamgr.cpp
Tested on LabVIEW 13.0.1f5 (32-bit) and LabVIEW 14.0f1 (32-bit), Windows 8.1 x64.
Certified LabVIEW Developer
(4,620 Views)
The silver controls have enough bugs that I just shy away from them.
Bill
CLD
(Mid-Level minion.)
(4,593 Views)
There's no silver bullet for that...
(4,548 Views)
Reproduced in 2011 SP1.
It works well to replace it with empty silver array and silver String array, just not the numeric array. I assume it has something to do with trying to move/translate the values. Since you dont have the numeric array in Modern i cant reproduce it with those.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,521 Views)
I have submitted CAR #497516 to track the problem. Thank you for reporting it.
(4,512 Views)
Accepted by JKSH
Hi all,
The CAR that DFGray originally submitted has been fixed in LabVIEW 2015! You can find a link to download here.
(4,248 Views)
Siana,
     Thank you for the followups on these older Forum reports of LabVIEW bugs that have been fixed in LabVIEW 2015.
(4,215 Views)
