[BUG] Subdiagram label breaks when converting from LV2013 -> LV2012
Before conversion:
After conversion:
If I then select the 2nd loop and hide its subdiagram label, the 'N' terminal moves up, ABOVE the loop (No snippet, because the 'N' simply disappears from the snippet).
There's no way to fix it, except to remove the loop and make a new one.
Certified LabVIEW Developer
(3,041 Views)
I opened it in LV 13 and saved in LV 12.  Opened it in LV 12 (and 13) and it worked fine.
LV 12 = 12.0.1f5
LV 13 = 13.0.1
Misread the post.  Let me continue the experiment.
Okay after hiding the subdiagram label, it still seems to work correctly.
Bill
CLD
(Mid-Level minion.)
(3,006 Views)
Sorry for not being clear before. My original snippets show:
  1. Original code in LV2013.
  2. What the code looks like after I converted it to LV2012 and opened it (without any other modifications).
This is what the code looks like AFTER I hide the subdiagram label in the converted code:
This happens regardless of whether I open the converted VI in LV2012 SP1 or LV2013.
Here are the details of my computer with LV2013:
  • Windows 8.1 64-bit
  • LV2013 (13.0f2) 32-bit
Perhaps it was fixed in LV2013 SP1? (I don't have that version yet)
(2,999 Views)
Accepted by JKSH
LabVIEW 2013 SP1 Bug Fixes
408914
Using save for previous on a for loop containing a subdiagram label in LabVIEW 2013 causes the loop N terminal to appear on top of the subdiagram label
Bill
CLD
(Mid-Level minion.)
(2,996 Views)
Gave you a kudo because you're the one that figured it out.  😉
Bill
CLD
(Mid-Level minion.)
(2,972 Views)
Gave you a kudo because you found and shared the confirmation from official sources 😉
(2,963 Views)
