BUG (?) while remote debugging: shows #0
Hello all,
it seems to be a bug while remote debugging.
When I switch on HIGHLIGHT function, it shows me "#0" at all array lines, but the passed arrays are not empty.
Here what it shows:
(see #0)
but the probe window shows that there are values:
@NI: Please try to reproduce and, if it is really a BUG, please correct.
Thanks.
Best regards
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(3,774 Views)
@EWiebe wrote:
Hello all,
Here what it shows:
(see #0)
@User002: Please try to reproduce and, if it is really a BUG, please correct.
Thanks.
Best regards
The arrays showing as length = 0 is a bug I can confirm seeing.
There is also a similar bug where probes on arrays running on a RT target show as empty when controls show data.
I don't know if there is a CAR for the "zero-length" but I do know there is CAR for the empty probes (that can get you searching backwards through code rather than forward). I think it a real pain but the severity does not seem to warent a fix as far as I know.
Ben
(3,745 Views)
Accepted by EWiebe
Hello Ben EWiebe,
i was able to reproduce this behavior on multible Systems (using LV 2011).
It seem to be bug so i created CAR: #342275.
Thanks to your help we are able to improve our Products.
Best Regards!
Moritz M.
(3,732 Views)
