Best Practices for Gracefull Application exit/close
I started removing the event structures. Take a look at my VI. Am I doing it right?
Message 11 of 12
(1,407 Views)
No, Do not use two event cases in the same loop. You can add to your other event case. Are there any subvi's that require user action to end?If so that subvi must be exited first before your vi will close.
Message 12 of 12
(1,403 Views)
