Best Way To Collect Production Data and Compare Against Limits
During production test, what seems to be the most efficient way for collecting lots of test data and then checking each one against limits?  I'd like to hear the LabVIEW community thoughts.  Thanks!
Message 1 of 8
(1,000 Views)
Hmmm that's a rather vague and open ended question....
Do you mean realtime limits as in pass/fail testing or aggregates like production yields and first pass test failures?
=== Engineer Ambiguously ===
Message 2 of 8
(994 Views)
Great question RTSLVU, I am actually looking at both:
1. Real Time Display of data on UI - With data read, test limits, and whether the data read passed withing limits
2. Data Collection Into Report File - Shows data read, limits, and pass/fail as well but all this test data is included in one file
Thanks!
Message 3 of 8
(984 Views)
Thanks!
All these are the standard features of TestStand, are you trying to recreate a sequencer?
Santhosh
Soliton Technologies
Message 4 of 8
(931 Views)
I recommend using a production database.
Retrieve test spec data by keying off: DTU_P/N, Test_Name, Step_Name, Parameter.
Data retrieved would be: Lower_Limit, Upper_Limit, Comparison Type, Abort_on_fail.
Message 5 of 8
(895 Views)
@Santhosh,
My requirement is not to use TestStand, only LabVIEW.  I understand TestStand capabilities.  I'm just looking for information specifically using LabVIEW only.  Thanks.
Message 6 of 8
(875 Views)
Can you elaborate more on your question ?
The answer varies depending your constrains:
- The amount of data.
- How fast you need the result
- Depending on the result (pass/fail) does the operator need to intervein ?
Message 7 of 8
(862 Views)
@testdesign wrote:
@Santhosh,
My suggestions are applicable to any platform.
Message 8 of 8
(849 Views)
