Binary indicator
Hi All !
I have binary number, say 00000101. I want to indicate every bit by corresponding led on the Front Panel.
So in this case it'll be led0 and led2 on.
How can i do it?
Message 1 of 8
(5,263 Views)
Accepted by john7
Hi John,
use the function "Number to boolean array", found in the boolean function palette...
Message 2 of 8
(5,261 Views)
Thanks a lot! Smiley Happy
Message 3 of 8
(5,249 Views)
...and reverse the array if you want the MSB to the left.
Ben
Message 4 of 8
(5,244 Views)
In addition you sometimes might want to reverse the array.
(In the binary numeric indicator, the lowest bit is on the right while the array starts with the lowest bit (i.e. it is on the left if the array indicator is horizontal).)
Message 5 of 8
(5,243 Views)
Ah c'mon, Type Cast man is shaking his fists right now, he knows you just Type Cast that number to a Boolean Array in 4.x mode and it is human readable. A gratuitous display of arcane LV functions is sure to impress your boss and coworkers as well.
Message 6 of 8
(5,236 Views)
STAND-BACK EVERYONE!
Darin is reaching for the type cast again.
Ben
Message 7 of 8
(5,230 Views)
LabVIEW 2012
Message 8 of 8
(5,210 Views)
